searching for a video converter from Computer to PAL SDI or Component
COW Forums : Broadcasting
RiotManZ
on Jan 12, 2007 at 3:43:28 pm
Hi all,
We're planning a show were we want to use three cameras(SD-SDI) and two computers as sources.
There are no problems with the cameras but i once heard i have to downconvert the computer signals from whatever resolution they have to PAL so i can use them with our digital videomixer.
do i need this downconverter for a SDI signal too or was this just for analog component signals.
If i need a converter, does anyone of you know a good company/ model to purchase?
thanks for your answers
Riot
bouke
Re: searching for a video converter from Computer to PAL SDI or Component
on Jan 20, 2007 at 8:26:28 pm
Anything wrong with a dirt cheap Decklink card?
Bouke
http://www.videoToolShed.com
smart tools for video pro's
JerryZ@BH
on Jan 22, 2007 at 3:44:30 pm
If the video source from the computer is coming from a NLE like Final Cut then you would just build your video in PAL and use an AJA or Decklink card to pipe the video out. If the source of the computer video is your desktop or Powerpoint then you will need a scan converter and format converter. The Folsom Image Pro SDI should do the trick.
http://video.folsom.com/products/index.cgi?index=1070327722_18404
jerryz@bhphotovideo.com
cow
RiotManZ
on Jan 23, 2007 at 9:19:35 am
@Jerry:
thanks for your great help. this model is perfect for us!
@bouke:
i'm not sure if the decklink card can be used for desktop systems. i will have to check the specs sheet.
anyway, thanks for your answer.
rock on
Riot
