component to composite cable
COW Forums : Broadcasting
Sam Lesante Jr.
on Jan 4, 2007 at 6:29:48 pm
hi all,
i was wondering if they made a wire that was the three component bnc into the one composite bnc.
if not, what's another solution?
tia
sam
Thax
Re: component to composite cable
by
on Jan 4, 2007 at 7:33:30 pm
Component will not "translate" to composite with just a cable.
You need a "transcoder" that will convert the signals.
However, if you have an "S-Video" output, you can simply combine the "Y" wire and the "C" wire together and it becomes a standard composite video signal.
Peterd
on Jan 10, 2007 at 8:12:35 pm
if you're really desperate in a pinch you can loop the component signal through a deck. Just go component into the deck and take composite out the deck into whatever you're dubbing to. This may not be as good as using a real trascoder and may require you to lock the video with a black burst generator.
