Textless Elements
COW Forums : Broadcasting
Nina Staum
Textless Elements
on May 13, 2006 at 5:04:46 am
I just got some broadcaster tech specs that ask for "textless elements" on the tape after the end of the show. How is this usually done? I know you take all the clean shots from under the chyron and throw them in at the end, but what about when there's a transition between shots? Do you have to go back (or forward) to the nearest hard cut, or do you just put in the one shot with enough material on either side to make the transition you have in there? It's an entertaiment show, so could get pretty transition-happy.
Matte
Re: Textless Elements
on May 13, 2006 at 12:10:43 pm
Ask whomever is making the request.
Nina Staum
on May 18, 2006 at 10:27:40 am
Thanks, I guess I just assumed there was a universal standard.
