RS232 to RS422 conversion
COW Forums : Broadcasting
Jason
on May 1, 2006 at 1:26:30 am
I have an AJA ioLA connected to a Sony DSR20 DVCAM deck (s-video) and a Sony UVW1800 BetaSP deck (component). I'm using the RS422 control from the AJA to control the Beta deck, but the DSR20 has RS232, so I've tried using firewire to control the DSR20, but the firewire connection for the AJA seems to be conflicting with the firewire I
Jon Zanone
Re: RS232 to RS422 conversion
on May 1, 2006 at 11:30:50 am
One off the top of my head is the Rosetta Stone (http://www.addenda-elect.com/product.htm. Any 9-pin A/B box should do the trick.
Jon
"The Almighty tells me He can get me out of this mess. But He's pretty sure you're F%$#*D!"
Jason
on May 1, 2006 at 1:59:29 pm
Someone else suggested I buy a RS232 to USB converter and create an easy setup for each deck.
Jon Zanone
on May 2, 2006 at 11:45:48 am
I like the serial port option - I never use it anymore, and it leaves my USB ports for other things (which are more common nowadays). Check out a Keyspan adapter (http://www.keyspan.com/products/homepage-Serial.spml) - it might be what you are looking for...
Jon
