Capturing analog video
COW Forums : Broadcasting
Nick Vaka
on Mar 22, 2006 at 3:26:05 pm
Hello:
Can anyone out there give me a good cheap solution to capture broadcast quality analog video? I need something that can capture at least DVD quality from tapes shot on VHS. I know I can't enhance their performance to DVD standars, but I don't want heavy compression. I found this one on B&H:
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&...
Anyone familiar with this?
Thanks.
Matte
Re: Capturing analog video
on Mar 22, 2006 at 3:36:14 pm
Capture it to WHAT?
An NLE edit system?
I recommend capture to a TimeCode tape first.
A DV camcorder that has the feature of analog inputs will do this.
Also, most DV camcorders that DO have the analog input feature will allow you to "transcode" analog-to-digital in real-time and capture directly via FireWire into a computer.
But I still recommend the "copy to TC tape" step.
It gives you the ability to recapture in the future and allows a "digital master" to be stored.
It can also make the VHS signal (which is usually pretty ugly and unstable) a bit more solid and easier to capture.
Nick Vaka
on Mar 23, 2006 at 2:17:50 am
It is going into an NLE (Premiere). I was trying to avoid using a DV cam but that's probably the best option. Thanks for the input.
Kerry
on Apr 5, 2006 at 5:39:07 pm
A Canopus ADVC100 or 300 works well for VHS to DV conversion. Built in TBC on the 300
KB
