mini dv video from ntsc to pal
COW Forums : Broadcasting
macmauro
on Feb 27, 2006 at 12:07:36 pm
hi from Maurizio - Italy
can i convert a ntsc mini dv tape to pal format
just copying the tape again
from a pal-ntsc dv player
to an another which uses pal?
or can I convert it otherway?
Matte
Re: mini dv video from ntsc to pal
on Feb 27, 2006 at 3:32:28 pm
No "deck-to-deck" systems conversion is possible (unless the deck SPECIFICALLY has this as a FEATURE (not just "switchable" between NTSC or PAL)
You would need to route the signal through a real-time hardware "box" Systems Convertor,
or
copy the footage into a non-linear edit system (like Final Cut Pro) and use software to do the conversion, then dub the footage back out to a deck set to the proper format.
