video or audio watermarking
COW Forums : Broadcasting
mYthprod
on Jan 27, 2006 at 10:50:46 pm
Anyone use any sort of watermarking for their spots? Either video or audio watermarking? We're looking at 3 companies so far: Confirmedia (verance), BVS (makes Veil), Teletrax.
- mYthprod
(John David Hutton)
* Build Your Own VelocityQ. See how * :
http://www.customflix.com/Store/ShowTtl.jsp?id=205835
Randy Pfeiffer
Re: video or audio watermarking
on Jan 31, 2006 at 12:26:45 am
The company I work for uses Verance, Veil , Teletrax, & Sigma (nielsen)...
Here's what I know (or think I know ;-))
Verance is an audio watermark (export audio for Avid, run thru encoder software, import encoded audio back into Avid and output-to-tape) - though I think they also have a "stand alone" box
Veil encodes its' watermark in video (uses full frame of video) encoding info on each line of alternating fields
Teletrax uses a portion of the video (I believe it encodes its' info in regions of high contrast, sharp lines, etc.)
and last but not least...
Sigma (nielsen) puts its' info in vertical interval (lines 20 & 22)
I'm sure there are others on the board who can add more to this thread, but I hope this gets you started
Cheers,
Randy
Mark Suszko
on Feb 1, 2006 at 7:56:20 pm
Companies have been marking using ultra-tiny CG type way out of safe title for decades. That's easy enough to defeat if you are looking for it, by masking or DVE-ing it out. Putting something in the close-captioned line 21 area is also done. I knew about digitally watermarking still images, but not about video, I'll have to check those companies out.
Michael D. Brown
on Feb 3, 2006 at 1:32:20 pm
Veil encoding degrades the picture.
Mike Brown
Video/Film Producer
American Heart Association
