which monitor for best view in video editing
COW Forums : Broadcasting
macmauro
on Oct 26, 2005 at 8:02:24 pm
hi from Italy
I'm new on broadcast and i work with media 100 on apple, using pal system and usually in digital format dvcam
i need an external monitor (no more a tv) to send signal and control video quality, colors etc..
I'm searching for professional but not expensive monitor, i can use bnc or other analogic output
from my computer. What i should search? What features I've to check?
Lcd or trinitron etc....
Any suggestion?
Matte
Re: which monitor for best view in video editing
on Oct 26, 2005 at 8:27:53 pm
If you want to view the most ACCURATE image, you still want to use a CRT (picture tube) monitor and NOT an LCD or Plasma display.
CRT monitors are no longer going to be made and you may be able to get a bargain if you look.
Sony brand "broadcast" monitors are very popular.
Google for "Sony Broadcast Monitor PAL".
S-Video, RGB, Component, and/or FireWire inputs (if your gear has any of those options) are preferred connections over BNC Composite.
Todd at UCSB
on Oct 28, 2005 at 5:31:44 am
Matte is spot on as usual.
The Sony BVM line is their Broadcast level monitors. So you might be surprised at the price. I've bought several monitors over the past couple of years, and I've always ended up the the Sony PVM line. For price and value, they are the best. Ikagemi makes great monitors as well, but they might be harder to get in Italy?
Good Luck,
Todd at UCSB
Television Production
macmauro
on Oct 28, 2005 at 12:55:34 pm
thanks for your suggestions
what about this monitor i found here in italy?
it costs 600 euro
JVC TM-H150CG
15''
pal e ntsc format
more than 750 tv lines (Y/C input mode)
slot port for optional componente/SDI card
switchable 4:3 16:9 aspect ratio
wired remote control
Scanning Frequency
H:15.625kHz (PAL)/15.734kHz (NTSC)
V: 50Hz (PAL)/59.94Hz (NTSC)
Color Temperature
6500
