Online photoshop tutorial/tips for editors
COW Forums : Broadcasting
John
by
on Sep 16, 2005 at 3:53:27 pm
Good day to all,
Does anyone know of a good website that would have tips or tutorials for editors needing to a) learn photoshop fundamentials, b) possible tips for AVID/FCP editors, such as making alpha mattes or to make a vignette.
I do not claim to be a graphic artist, nor do I want to become one, but I would like to be able do some of the basic things that I encounter every day.
I thank all in advance for your help.
John
Thax
Re: Online photoshop tutorial/tips for editors
by
on Sep 29, 2005 at 1:04:00 am
To get you started for Final Cut Pro.
First, the basics:
http://www.kenstone.net/fcp_homepage/basic_ps.html
Create an Alpha Channel in Photoshop:
In this example:
A logo sits on a red background.
Make an alpha channel so the red background won't show up, just the logo.
"Quick and Dirty" Alpha Channel Tutorial (for this image, anyway).
1. Open unaltered original image in Photoshop.
2. Touch the "Magic wand" tool, set the tolerance to 36.
3. UN-check (do NOT check) "Contiguous".
4. Touch any part of the red area with the Magic Wand tool.
5. Make sure all of the red area is selected.
6. Select (menu) > Save Selection...
7. Go to Photoshop CHANNELS Window and see if there is now an Alpha Channel in the shape that you want.
8. Then File (menu) "Save As"
9. Choose PICT as the type of file and re-name this file what you want.
Done.
Drop this new PICT file into FCP.
Click it into the FCP Viewer window and then:
Modify (menu) > Composite Mode > Normal
Modify (menu) > Alpha Type > Straight
You might need to choose "Reverse Alpha"
Done.
Matt Larson
on Sep 30, 2005 at 8:39:03 pm
It's not online, but it sounds like you need Richard Harrington's Photoshop for Video Editors book: http://www.amazon.com/exec/obidos/tg/detail/-/1578202094/103-7711638-250303...
I bought that when I got Photoshop and it was a huge help. Set up very well around things you actually need to do as an editor, good DVD included too.
