SE-800
COW Forums : Broadcasting
Helton
SE-800
on Sep 5, 2005 at 10:20:27 pm
I bought a SE-800 mix, and I pluged 3 cameras on it. Useing the analog conection(BNC) and now I want record the final work directly throuth the dv out(fireware)to a laptop. Is that possible, becouse I've got no image on the laptop and I tryed throuth the analog output(BNC) but I've got no image to. Does anyone can help me the computer is fine, because I conected the camera with the laptop and works. Is there any config at the mix that I didint understend?
Thanks.
Matte
Re: SE-800
on Sep 6, 2005 at 2:12:11 pm
You need computer sofware that will capture DV via firewire.
It needs to be set to "non-controllable device" so the software does not look for a deck, camera, or running timecode.
OTOH, it would be more "safe" if you were to record the output to DV TAPE first, then capture to the computer.
