capturing DVCPro on a DSR-1500AP
COW Forums : Broadcasting
duffbeer911
on Sep 1, 2005 at 6:50:49 am
We have a DSR-1500AP and when I playback my DVCPro tape I get vertical lines all over the screen. The lines are about 10pixels wide and evenly spaced. I can sort of see the vision behind, but it is not very clear. I'm not sure if it is shot DVCpro50 or 25. And in fact I have not had any experience with this deck or format in the past. ANy ideas where to start?
Cheers in advance
Jon Zanone
Re: capturing DVCPro on a DSR-1500AP
on Sep 1, 2005 at 3:42:09 pm
Get a Panasonic deck. You can't play back DVCPro on a Sony deck...
duffbeer911
on Sep 2, 2005 at 12:36:00 am
doh - are you positively sure????? cause when I look up the deck on google everywhere says it can playback DVCpro.... http://www.bhphotovideo.com/bnh/controller/home?A=details&Q=&is=REG&O=produ...
http://www.broadcast.com.tr/partners/sony/dsr1500ap.asp
Thanks for your help
Jon Zanone
on Sep 2, 2005 at 3:39:27 am
What you describe sounds like DVC Pro 50 being played in a 25 deck, hence my assertion that Sony can't play DVC Pro. In my sleep deprived response, I should have said it can't play back DVC Pro 50. Is your source tape 50? Remember, you can shoot 50 on a 25 tape, so don't go by what the tape label says. Of course I've seen a really wierd artifact on 25 where a reused tape showed both the old shot and the new shot on the same frame. I'll have to dig that out and steal a frame from it - it's kinda' weird....
Jon
duffbeer911
on Sep 2, 2005 at 3:54:45 am
it must be 50. Cheers for the help.
tony salgado
on Sep 8, 2005 at 3:34:32 pm
The dsr 1500A only plays back dvcpro which is 25mb 4:1:1. DVCPRO 50 is 50 mb 4:2:2 and will not playback on the dsr-1500A. DVCPRO 50 playback requires a Panasonic vtr which is capable of playing back dvcpro 50.
FYI when playing back dvcpro in the dsr-1500A the only active outputs are the analog outputs not the firewire.
Tony Salgado
