field monitors
COW Forums : Broadcasting
Jim Mulleder
field monitors
on Aug 4, 2005 at 11:14:02 pm
Howdy cowsters and video pros,
I am looking at some field monitor options that use regular rechargeable batteries. I am looking for a SD (but could have HD) monitor that will run on Nickel Metal Hydride double A's or simliar. It would be a plus if the monitor had a power adaptor option to act as a program monitor for my camera on a multi-cam sports mobile.
Any thoughts???
Cheers
Jim
Jim Mulleder
Techical Producer
http://www.telestudios.ubc.ca
Bob Pennington
Re: field monitors
on Aug 5, 2005 at 5:48:29 pm
Jim: Most of the monitors with a nice resolution usually draw current that requires larger rechargeable batteries. Anton/Bauer offers 14.4 volt batteries that handle the power draw for most professional batteries. If you are intersted in powering small 7.2 volt cameras, we offer Gold Mount (Anton/Bauer) battery mounts that have a voltage converter built in so you can power your 7.2 volt camera with a 14.4 volt battery.
http://www.antonbauer.com/7_14_gold_mounts.htm
