Video distribution amp - suggestions?
COW Forums : Broadcasting
Barend Onneweer
on Jul 2, 2005 at 6:40:26 pm
Hi all,
I'm currently editing and grading video using a Decklink board - hooked up to a Sony 14" Video Ref monitor. But I'd like to add a consumer grade TV set to the setup, to get some feedback on what the picture will look like on a less accurate (and more average) screen.
So I'm probably needing a video distribution amp with component inputs, and multiple simulaneous outputs. I need component out for the Sony ref monitor, and would like S-Video output for a consumer monitor.
The only thing that seems to do this that I can find is this:
http://www.bhphotovideo.com/bnh/controller/home;jsessionid=CGcSxN08zQ!19681...
Any suggestions? Thanks in advance :-)
Bar3nd
Forum COWmunity leader for:
ADOBE AFTER EFFECTS
MAGIC BULLET SUITE
INDIE FILM & DOCUMENTARY
Thax
Re: Video distribution amp - suggestions?
by
on Jul 5, 2005 at 11:54:30 am
[Barend Onneweer] "I'd like to add a consumer grade TV set to the setup, to get some feedback on what the picture will look like on a less accurate (and more average) screen."
There IS no such thing.
Out of 95 "average" TV screens 100 of them will look different :-)
By this I mean many consumers "ADJUST" their sets frequently ("if its on the remote control, USE it") and, (just as bad) many with really AWFUL settings... DON'T!
And, as the sets age, they change and NEED adjustment.
By hooking up an "average" TV monitor to your system, you will only be seeing what THAT "average" TV monitor happens to look like at the moment.
That's why we try to use the "ideal" monitor and adjust the image to be "RIGHT" under the best conditions.
Besides, what action would you take if the "Pro monitor" looked great, but the "average monitor" looked a bit red and fuzzy?
I hope you'd adjust the "average monitor" to better match the "Pro monitor"... and we're back to square one.
I suppose that if you use a monitor with less rez than the pro set to judge font size it would be a bit useful, but once you determine that number, you then KNOW it.
This "worst case" monitor is very common in audio because being able to hear a mix thru small speakers at lower levels (if radio is the ultimate use) CAN be valuable (but judging color-match and chroma-levels for broladcast are a different story).
Todd at UCSB
on Jul 6, 2005 at 5:22:35 am
Hi Barend,
Although Thax is correct, I've set up and seen a lot of suites that include a consumer monitor. Although the colors will be off, it's still a reference for clients to see what it 'can' look like on a normal TV. I've haven't had any problem routing audio to sync.
I'm surprised that you need the converter. The decklink doesn't have a composite out?
We use a JVC S-video switcher for our edit suites, it works fine and is around $500. I don't think they make them anymore...
But once you start needing to convert from component to composite, it gets pricey. If you can't use a composite signal or S-video, then, I'd go with the Laird.
Good Luck,
Todd at UCSB
Television Production
