unable to update to new version
max arch
on Mar 17, 2016 at 4:18:37 am
i using mac os 10.9.5
here the code
Max-MacBook:ffmpeg maxime$ ./ffmpeg -i ...". Notice the "./" before the "ffmpeg
ffmpeg version 3.0-tessus Copyright (c) 2000-2016 the FFmpeg developers
built with Apple LLVM version 6.0 (clang-600.0.57) (based on LLVM 3.5svn)
configuration: --cc=/usr/bin/clang --prefix=/opt/ffmpeg --as=yasm --extra-version=tessus --enable-avisynth --enable-fontconfig --enable-gpl --enable-libass --enable-libbluray --enable-libfreetype --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopus --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzmq --enable-version3 --disable-ffplay --disable-indev=qtkit --disable-indev=x11grab_xcb
libavutil 55. 17.103 / 55. 17.103
libavcodec 57. 24.102 / 57. 24.102
libavformat 57. 25.100 / 57. 25.100
libavdevice 57. 0.101 / 57. 0.101
libavfilter 6. 31.100 / 6. 31.100
libswscale 4. 0.100 / 4. 0.100
libswresample 2. 0.101 / 2. 0.101
libpostproc 54. 0.100 / 54. 0.100
.... Notice the ./ before the ffmpeg: No such file or directory
Max-MacBook:ffmpeg maxime$ ffmpeg
FFmpeg version SVN-r26402, Copyright (c) 2000-2011 the FFmpeg developers
built on Mar 15 2016 20:03:05 with clang 6.0 (clang-600.0.57)
configuration: --enable-libmp3lame --enable-shared --disable-mmx --arch=x86_64
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 1 / 0.16. 1
libavcodec 52.108. 0 / 52.108. 0
libavformat 52.93. 0 / 52.93. 0
libavdevice 52. 2. 3 / 52. 2. 3
libavfilter 1.74. 0 / 1.74. 0
libswscale 0.12. 0 / 0.12. 0
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Use -h to get full help or, even better, run 'man ffmpeg'
max arch
Re: unable to update to new version
on Mar 17, 2016 at 4:49:23 am
==> Summary
