script error
Peter Robertson
script error
on Jul 3, 2013 at 3:19:45 pm
I was able to make a script a few months ago with the generous help of this forum but now it has stopped working. When I try to run:
#!/bin/sh
for (( i=0; i<97; i+=30 ))
do ffmpeg -ss $i -t 10 -acodec copy -vcodec copy -i movie.mp4 index_$i.mov
done
I get the error:
./IndexVidBash.sh: line 1: {rtf1ansiansicpg1252cocoartf1187cocoasubrtf390: command not found
./IndexVidBash.sh: line 2: syntax error near unexpected token `}'
./IndexVidBash.sh: line 2: `\cocoascreenfonts1{\fonttbl\f0\fmodern\fcharset0 Courier;\f1\fnil\fcharset0 LucidaGrande;}'
Any suggestion on how to fix this?
Peter
Pedro
Peter Robertson
Re: script error
on Jul 3, 2013 at 3:56:33 pm
My bad. The error appears to have been caused by the fact that I was using Text Edit to edit my .sh file--not a good idea. Saving the script with a different editor fixed the problem.
FYI--the syntax for ffmpeg has changed since I used this script. With newer versions of ffmpeg you will need to use
do ffmpeg -ss $i -t 10 -i YUWinter.mp4 -acodec copy -vcodec copy index_$i.mov
the '-acodec copy -vcodec copy' needs to be placed AFTER the output file.
Peter
Pedro
Lou Logan
Re: script error
on Jul 5, 2013 at 8:57:21 pm
[Peter Robertson] "the '-acodec copy -vcodec copy' needs to be placed AFTER the output file."
Don't you mean "after the *input* file"? Please use the CODE button on your commands and console outputs.
