how to convert .mov (animated gif) into .flv or .mp4
alain dazzi
on Mar 25, 2012 at 3:34:23 am
I am unable to convert a .mov video (comprising 2x video/gif streams) into flv other. This file looks like an animated gif actually, Can anyone help?
ffmpeg -i 633.mov
ffmpeg version N-37137-g749e5dc Copyright (c) 2000-2012 the FFmpeg developers
built on Mar 16 2012 16:45:08 with clang 3.0 (tags/Apple/clang-211.10.1)
configuration: --disable-decoder=amrnb --extra-cflags=-I/usr/local/include --extra-ldflags=-L/usr/local/lib --enable-nonfree --enable-gpl --enable-version3 --enable-postproc --enable-swscale --enable-avfilter --enable-libmp3lame --enable-libvorbis --enable-libtheora --enable-libfaac --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libxvid --enable-libx264 --enable-libvpx --enable-hardcoded-tables --enable-shared --enable-pthreads --disable-indevs --cc=clang
libavutil 51. 34.101 / 51. 34.101
libavcodec 53. 59.100 / 53. 59.100
libavformat 53. 30.100 / 53. 30.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 60.100 / 2. 60.100
libswscale 2. 1.100 / 2. 1.100
libswresample 0. 6.100 / 0. 6.100
libpostproc 52. 0.100 / 52. 0.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x7feb5183d800] multiple edit list entries, a/v desync might occur, patch welcome
Last message repeated 1 times
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x7feb5183d800] Could not find codec parameters (Video: none (blur / 0x72756C62), 160x120, 0 kb/s)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '633.mov':
Metadata:
creation_time : 2003-12-16 16:25:56
Duration: 00:00:02.06, start: 0.000000, bitrate: 34 kb/s
Stream #0:0(eng): Video: gif (gif / 0x20666967), pal8, 160x120, 152 kb/s, 15 fps, 15 tbr, 600 tbn, 600 tbc
Metadata:
handler_name : ?Apple Alias Data Handler
Stream #0:1(eng): Video: none (blur / 0x72756C62), 160x120, 0 kb/s, 0.50 fps, 0.50 tbr, 600 tbn, 600 tbc
Metadata:
Stream #0:2(eng): Video: gif (gif / 0x20666967), pal8, 160x120, 152 kb/s, 15 fps, 15 tbr, 600 tbn, 600 tbc
Metadata:
and the command I use is ...
~/Desktop/robert$ cat g
ffmpeg -y -i 633.mov -vcodec flv
-pix_fmt yuv420p
-b:v 900k
-an -r 15 -vf scale="426:320" test.flv
The resulting streams is ...
~/Desktop/robert$ ffmpeg -i test.flv
Input #0, flv, from 'test.flv':
Metadata:
encoder : Lavf53.30.100
Duration: 00:00:00.06, start: 0.000000, bitrate: 1201 kb/s
Stream #0:0: Video: flv1, yuv420p, 426x320, 900 kb/s, 1k tbr, 1k tbn, 1k tbc
comment:3
The length is .06 seconds instead of 2.06 seconds.
