DOWN CONVERSION ISSUE: From MXF (1080i AVC Intra) - MBAFF "interlacing" to DVCPRO
Iban Txo
on Mar 23, 2012 at 10:40:04 am
Hi!
I am trying to down convert a MXF:
Stream #0:5: Video: h264 (High 4:2:2 Intra), yuv422p10le, 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 25 tbn, 50 tbc
It has a MBAFF interlacing inside (Mediainfo tells it).
With ffmpeg I can get a DV, but it is de-interlaced and I want to be interlaced with the original "fields".
How can I get it using ffmpeg?
Many Thanks
