ffmpeg adding white frames & extending end of .mov due to longer audio
chris graham
on Feb 15, 2012 at 3:53:16 pm
hey guys we're using ffmpeg to output a H264 .mov from a series of .png's @24fps
works fine without audio
however when we add the .aifc audio ( that is supposed to be the same length ) it adds a couple frames of white at the end
is there a simple way to just truncate the audio to the length of the footage, if it is too long?
thanks!
stephen dixon
Re: ffmpeg adding white frames & extending end of .mov due to longer audio
on Feb 16, 2012 at 11:49:23 am
use -shortest. As in ffmpeg -shortest -i inputone-%05d.png -i inputtwo.wav -map 0:0 -map 1:0 output.mov. It will truncate the output to the length of the shortest input stream
