Decoding x-rtvc1 RTP Streams ?
Christian Rheims
on Dec 17, 2011 at 12:04:49 am
Hello,
Does anyone know how to decode the Video Streams from e.g. MSN Messenger 2011 ?
The new Windows Live Messenger uses rtvc1 as Video Stream. The earlier versions used ml20 as stream.
I managed to decode all I-Frames of such stream, but i cannot decode the B and P Frames.
rtvc1 is a VC-1 based Codec, but it has some modifications for the RTP transmission.
If i decode the I Frames, the Video runs too fast, because there are the B,P frames missing. The B,P frames are in my stream File, but the Decoder of ffmpeg only accepts the I Frames and skippes the B,P frames.
I hope someone here is interested in decoding this streams, on roundup i´ll got responses from some users, but after a while they dropped the idea of decoding rtvc1 :(
Sorry for my bad english
Greetz Chris
zeel zeel
Re: Decoding x-rtvc1 RTP Streams ?
on Nov 19, 2012 at 10:54:58 am
i can't able to decode b,p and sp frame of x-rtvc-1 codec video file..
so if u have any solution..
plz give update on this Registered id..zeeltesting402@gmail.com
regard
zeelzeel
zeel zeel
on Nov 19, 2012 at 11:05:16 am
when i try to play msn wireshark capture rtvc.vc1 file by removing all cc000000 and dc000000 then using ffmpeg it playing but we getting some error
1>Luma scaling is not supported, expect wrong picture.
2>Chroma scaling is not supported, expect wrong picture.
and video playing so fast.
so there is some specific decoder or player to play that file.
note:={i think there is some mac player can able to play but i m not sure..}
give reply
on this id zeeltesting402@gmail.com
