File for preset 'hq' not found
Magnus Karlsson
on May 17, 2011 at 5:55:49 pm
How come i get the following when trying to convert?
Michael Rampe
Re: File for preset 'hq' not found
on May 17, 2011 at 10:50:43 pm
[Magnus Karlsson] "How come i get the following when trying to convert?
File for preset 'hq' not found"
Was it working before and now not working or is this a first use error?
Could be a couple of things....
If you are using an *older* version:
The hq preset has been missing for some time now. Check the FFpresets folder for available preset options.
If you are using a *newer* version:
The command line options changed recently for libx264. The -vpre option has been replaced by a method calling the x264 presets direct. -preset, -profile & -tune are the new options to replace the -vpre use. Check the x264 docs for a full list of available options.
Can you post your command line and output to verify the error/version?
Michael
