ffmpeg scaling issue
Jack Passmore
on Sep 29, 2010 at 6:43:29 pm
Hi all,
I'm trying to convert a large 1920x1080 .avi file (8-bit mjpeg Blackmagic codec) to an h246 encoded mp4 file using ffmpeg at the command line. The 1920x1080 original image is a pillar-boxed 4:3 image, so I'm trying to crop the sides off to eventually create a 640x480, 4:3, H264, .mp4 video.
The problem is, when I use ffmpeg, I can successfully crop the sides, but the .mp4 output is only the top left corner (640x480) of the original 1920x1080 video. I want to crop the original video and then scale the cropped 4:3 video (1440x1080) down to 640x480. Any suggestions? This is the ffmpeg code I'm using:
ffmpeg -i videos.avi -cropleft 240 -cropright 240 -vcodec libx264 -vpre normal video.mp4
John
Michael Rampe
Re: ffmpeg scaling issue
on Sep 29, 2010 at 8:50:45 pm
I am not sure why you are getting a 640x480 output at all without using the size flag (-s).
What version are you using? In the newer SVN versions, libavfilter is a better option for cropping and scaling (-vf).
Please post full output and I can work on a string to suit.
Michael
Jack Passmore
on Sep 30, 2010 at 9:31:54 pm
Hi Michael,
You are correct I wasn't getting a 640x480 image, I must have left that out. I was unaware of the -vf command, so thank you. However, I'm still having some problems.
This command will change the 1920x1080 letterboxed video to a 1140x1080 4:3 video correctly:
ffmpeg -i video.avi -vf "crop=240:0:1440:1080" video_crop.mp4
But when go back to the original file and try to also scale the image, it creates a 640x480 image that is stretched vertically and letterboxed:
ffmpeg -i video.avi -vf "crop=240:0:1440:1080" -vf "scale=640:480" video_crop_resize.mp4
I can't figure out why I'm not getting a 4:3 630x480 video file without letterboxing...
Michael Rampe
on Oct 1, 2010 at 1:57:57 am
[Jack Passmore] "
I can't figure out why I'm not getting a 4:3 630x480 video file without letterboxing..."
[Jack Passmore] "This command will change the 1920x1080 letterboxed video to a 1140x1080 4:3 video correctly:
ffmpeg -i video.avi -vf "crop=240:0:1440:1080" video_crop.mp4"
(careful with number typos, it can get very confusing;-)
Your command line will only use the last instance of -vf as it is only meant to be specified once per input.
The correct usage of -vf is comma separated commands with branches separated by semi-colons.
In your case (no branches):
ffmpeg -i video.avi -vf "crop=240:0:1440:1080,scale=640:480" video_crop_resize2.mp4
BONUS TIP:
...using libavfilter for a watermark (with a branch):
(bug1.tif=50x100 file saved with transparency from p-shop)
Using SoC libavfilter [1.20. 0]
-vf "movie=0:tiff:bug1.tif [watermark];\
[in] [watermark]overlay=1600:700:1[out]"
or the hack using SVN libavfilter [1.39. 0] if you get an error with the overlay:
-vf "movie=0:tiff:logo5.tif,pad=1920:1080:1600:700:0x00000000 [watermark];\
[in] [watermark]overlay=0:0:1[out]"
...and it works with multiple separate or nested branches as well.
Michael
Jack Passmore
on Oct 1, 2010 at 3:12:37 pm
Awesome, it works. Apologies for my typos! Now I just have to find the correct h264 presets for decent web viewing.
Cheers,
John
