Need advice with VirtualDub Encoding/Saving avi
Adam Neznamy
on Jan 4, 2019 at 10:27:20 am
Hello, im currently restoring few videos on virtual dub and i would want to know what is the best compression codec i can use. I can choose from those one:
Currently im thinking about fraps one since the uncompresed rgb one have crazy file size. Any tips or something? Thank you guys :)
Craig Seeman
Re: Need advice with VirtualDub Encoding/Saving avi
on Jan 4, 2019 at 2:59:39 pm
It depends on what your intent is with the resultant files. VirtualDub hasn't been updated in more than five years and doesn't support some of the "modern" codecs preferred in typical video post production workflows.
If you can access x264 encoder that might be a workable option but it would be .mp4 extension. Again it's not clear what your intent is. x264 wouldn't be my choice for post production work.
Jeff Pulera
on Jan 17, 2019 at 5:28:15 pm
Install the free Lagarith .avi codec. Makes big files, but lossless quality. That is then your "master" of the converted file. From that .avi, create any deliverables like .mp4 then using other software such as ffmpeg
Jeff
