Command line compressor fails
Loren Risker
on Jul 13, 2018 at 7:42:57 pm
I can't get compressor to work from the command line, I get an error:
2018-07-13 12:38:11.801 Compressor[94312:4645537] Error loading /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver: dlopen(/System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver, 265): no suitable image found. Did find:
/System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver: mach-o, but wrong architecture
/System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver: stat() failed with errno=1
Invalid parameter: /Users/lorenr/Library/Application Support/Compressor/Settings/Apple ProRes 422 test.cmprstng
Here's what I'm trying to run:
/Applications/Compressor.app/Contents/MacOS/Compressor -jobpath ./test.mp4 /Users/xxxxx/Library/Application\ Support/Compressor/Settings/Apple\ ProRes\ 422\ test.cmprstng -locationpath ./testoutput.mp4
Any ideas? I'm running macOS 10.13.6 and compressor 4.4.1
OutOfFocus.TV - Music Videos 24/7
Loren Risker
Re: Command line compressor fails
on Jul 13, 2018 at 8:02:09 pm
never mind, forgot the -settingpath flag:
/Applications/Compressor.app/Contents/MacOS/Compressor -jobpath ./test.mp4 -settingpath /Users/xxxxx/Library/Application\ Support/Compressor/Settings/Apple\ ProRes\ 422\ test.cmprstng -locationpath ./testoutput.mp4
