Bit rate adjustments in Compressor 4.4?
Charles Ford
on Jan 18, 2018 at 9:00:20 pm
My client wants a max bit rate of 2000 for a 30 sec. .mov. I can't find a way to adjust bit rate in Compressor 4.4. I only see "data rate". Any help?
Craig Seeman
Re: Bit rate adjustments in Compressor 4.4?
on Jan 18, 2018 at 9:04:08 pm
Bit rate and data rate are two ways of saying the same thing. Data is often measured in bits so they may be used interchangeably.
