best file formats and compression for webbed
Ty Ford
on Jun 30, 2016 at 12:06:41 am
I have a client who makes power point presentations and we have tried to use his slides to make a video in FCP X that will be narrated and run as a webinar.
even outputting an ,mp4 at 1280 results in a softening of the text and graphics. And on screen for the webinar, the softening is even worse. As long at the text isn't too small, I'm OK, but are there any rules to working this way that might increase the sharpness if the text and images?
Ty Ford
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford's Blog
Ivan Myles
Re: best file formats and compression for webbed
on Jul 4, 2016 at 11:29:26 pm
If there isn't much animation or video try increasing key frame distance to 90-120 frames (or longer), increase maximum bit rate, and use multi-pass encoding. If the slides are all static (text and images only) also try reducing frame rate to maybe 6-10 fps.
What export settings are you using? It would be helpful if you posted a screen capture.
