Compressor Won't Open
Glenn Payne
on Feb 24, 2016 at 4:50:03 am
Hey guys,
I have an older macbook pro that I'm still running the fc studio 2 on. mac os x 10.6.8. I recently wiped the old laptop clean and reinstalled everything and now my Compressor 3 won't open. I'm getting the message posted below. Any thoughts on what I can do to right this ship? Sorry if this is posted in the wrong forum. I wasn't sure exactly where to post it. Thanks for any help!
Process: Compressor [6351]
Path: /Applications/Compressor.app/Contents/MacOS/Compressor
Identifier: com.apple.compressor.Compressor
Version: ??? (???)
Build Info: Compressor-3017801~29
Code Type: X86 (Native)
Parent Process: launchd [105]
Date/Time: 2016-02-23 22:40:50.052 -0600
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 520526 sec
Crashes Since Last Report: 1
Per-App Crashes Since Last Report: 1
Anonymous UUID: A6F43493-720D-41C2-9584-A5CA2F9BC5A9
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Library not loaded: /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
Referenced from: /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
Reason: image not found
Binary Images:
0x8fe00000 - 0x8fe4163b dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
Model: MacBookPro3,1, BootROM MBP31.0070.B07, 2 processors, Intel Core 2 Duo, 2.2 GHz, 4 GB, SMC 1.16f11
Graphics: NVIDIA GeForce 8600M GT, GeForce 8600M GT, PCIe, 128 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x87), Atheros 5416: 2.1.14.6
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
PCI Card: pci168c,24, sppci_othernetwork, PCI Slot 5
Serial ATA Device: FUJITSU MHY2120BH, 111.79 GB
Parallel ATA Device: MATSHITADVD-R UJ-857E
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8205, 0x1a100000 / 2
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8502, 0xfd400000 / 2
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x021a, 0x5d200000 / 3
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x5d100000 / 2
