Which codec am I missing in this mp4?
Lucy Moon
on Feb 17, 2016 at 5:23:41 pm
Hi all.
I am trying to re-edit some .mp4's which my 2014 Mac (10.9.5) refuses to open in Premiere CC and Quicktime 10.3
They play in VLC (doesn't everything!) but I can't recompress with MPEG Streamclip, and Flip4Mac couldn't read them. I'm pretty sure they came from a Windows' based editor's setup.
(EDIT) I'm pretty sure it's ms-mpeg4v2-macosx.sit I'm looking for - some older Windows codec, but any links to it on the web are dead (/EDIT)
(EDIT2)I may have been on the wrong path above with that codec, since the other editor uses Media Encoder with the same settings as me, but on Windows. I think they have corrupted somewhere in transit, or my machine is crazy... Am uploading a sample file, if anyone loves this kind of mystery, msg me (if you can on creativecow?) (/EDIT2)
I'd rather find the codec if I can so I can import them to Premiere...
This is iMediaHUD output..
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 170 MiB
Duration : 35mn 28s
Overall bit rate mode : Variable
Overall bit rate : 671 Kbps
Encoded date : UTC 2015-02-27 12:55:14
Tagged date : UTC 2015-02-27 12:55:14
©TIM : 00:00:00:00
©TSC : 25
©TSZ : 1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 3 frames
Format settings, GOP : M=1, N=33
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 35mn 28s
Bit rate : 543 Kbps
Width : 1 024 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.037
Stream size : 138 MiB (81%)
Language : English
Encoded date : UTC 2015-02-27 12:55:15
Tagged date : UTC 2015-02-27 12:55:15
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 35mn 28s
Source duration : 35mn 28s
Bit rate mode : Variable
Bit rate : 126 Kbps
Maximum bit rate : 213 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 31.9 MiB (19%)
Source stream size : 31.9 MiB (19%)
Language : English
Any ideas?
Thanks.
MacBookPro 2.8 GHz intel core i7/ 16 GB RAM / NVIDIA GeForce GT 750M 2048 MB
Adobe Creative Suite Cloud
