Turning off Multiple Audio Channels when Converting MKV file to PS3 friendly Format
Kent Kitzman
on Feb 9, 2016 at 10:21:34 pm
New twist on a pretty common problem... I'm trying to convert a MKV file to any PS3-friendly format using VLC.
Many people have had problems getting the audio to convert. My problem is that I have TOO MUCH audio converting. The MKV file has several audio streams in its codec (Spanish language, French Language, Audio Commentary, etc).
What happens when I convert is that VLC takes ALL of these streams and smashes them together into 1 very confused-sounding audio track.
So my question is, can I turn off everything except the English track before converting?
Here are the basics of what I am doing...
Encapsulation = Mpeg-PS
Video Codec = H.264
Audio Codec = Mpeg Audio
If I stray away from any of these settings, I don't get any audio at all (at least not that my PS3 will play).
Let me know if I should try different settings, or maybe a different program altogether?
Bram van Dam
Re: Turning off Multiple Audio Channels when Converting MKV file to PS3 friendly Format
on Jul 5, 2016 at 9:31:37 am
Have you tried Handbrake? It has a very nifty feature that you can use to select different audio tracks and has a build in preset for PS3 if I'm not mistaken.
