Compressing down to a certain size - Apple Compressor
Chuck Purnell
on Dec 9, 2015 at 4:49:37 am
I need to submit some work and they are limiting work to be no larger than 300mb. One of my videos is just over 400mb and I have another one that is 1gb. I use a Youtube preset with my Matrox MX02 box when I post anything to youtube. It does an excellent job of compressing. I just need to know what I need to do to get my files smaller so I won't go over there 300mb size limit. I am thinking I am going to have to play with the settings within the preset that I use. Just not sure which one will reduce the size of the video.
Thanks for any advice or suggestions you may have!
Cre8tive Minds Entertainment, LLC
Ivan Myles
Re: Compressing down to a certain size - Apple Compressor
on Dec 9, 2015 at 5:53:22 am
File Size = Bitrate x Duration
If you need to reduce file size from 400MB to 300MB, reduce the bitrate to 300/400 = 75% of the current rate. If the resulting quality is unsatisfactory, consider reducing the image resolution (from 1920x1080 to 1600x900, or from 1280x720 to 1024x576, for example).
Chuck Purnell
on Dec 11, 2015 at 4:37:09 pm
Thanks Ivan, I will give that a shot!
