Can someone suggest how to prepare a video with these specs: 3840 x 1080?
Thackston Addy
on Oct 4, 2015 at 9:00:20 pm
Hi!
The final output is for a large video projection. Specs provided by Clear Channel Airport. Full specs attached.
I’m working in Premiere CC. My source footage was shot at 1920 x 1080 and I'm editing native. or rather I have been on the rough cut. Not sure how to go about achieving the following output and placement.
They want:
thanks in advance.
Ivan Myles
Re: Can someone suggest how to prepare a video with these specs: 3840 x 1080?
on Nov 18, 2015 at 11:49:51 pm
Set the sequence to 3840x1080 and scale the footage 200%, or
Set the sequence to 1920x540 and set the output dimensions to 3840x1080 when exporting.
The easiest way to create the 640x1080 black bar is using the Title function to insert a black rectangle on the uppermost track in your timeline. Alternatively, you could crop each clip, but this becomes troublesome if the video is moved.
