Adobe Premiere CS6
Chad MacKenzie
Adobe Premiere CS6
on Oct 12, 2014 at 5:16:36 am
Hi all,
A little confused when exporting this video because it looks interlaced and a little blurry. My sequence settings are: DSLR - 1920 x 720 - Square aspect ration
My export settings are H.264 - Vimeo HD 23.976 - Maximum Render quality.
Is there anything to do to make the quality look better?
https://vimeo.com/108689785
Thanks all
Jeff Pulera
Re: Adobe Premiere CS6
on Oct 20, 2014 at 1:26:24 pm
Is your source 1920x1080 or 1280x720? You said 1920x720 which I assume to be a typo.
Is the footage natively 23.97?
If you can post a screen grab of the Export setting panel that will be helpful in troubleshooting.
Max Render Quality is typically used for SCALING footage - if source and export are the same size, you may not need that turned on.
Jeff Pulera
Safe Harbor Computers
