not able to modify a copy of the default Compressor setting for dvd
Paul Dougherty
on Sep 10, 2014 at 8:54:04 pm
not able to modify a copy of the default Compressor setting for dvd - field dominance
In Apple Compressor I'm not able to modify a copy of the default Compressor setting for dvd (stuck on Automatic for field dominance) to ensure that the result is Interlace. I tried the default already (the source was 23.98 progressive) but there are motion artifacts in the result, again to ensure that the result is Interlace… unless someone has an idea what else might be wrong
Paul
Eric Strand
Re: not able to modify a copy of the default Compressor setting for dvd
on Sep 11, 2014 at 8:14:31 pm
Hi Paul,
I simply don't think you can create a 23.98 interlaced DVD; 23.98 is always progressive.
@ericstrand11
