How to prevent rendering when compressing
Ben Schramm
on Sep 8, 2014 at 3:02:46 pm
I am sending many unrendered video files from FCP7 to the compressor. They are not rendered because I do not have the time to spend on that process. However, FCP7 is rendering on its own during this time, which slows the compressing process. Is there any way I can set FCP7 to not render without being prompted to do so, or is there an option on the compressor to do this? Thanks in advance!
Craig Seeman
Re: How to prevent rendering when compressing
on Sep 8, 2014 at 7:01:13 pm
Maybe you should upgrade to FCPX or Premiere Pro CC.
Personally I'd recommend exporting a ProRes Master file and using that in Compressor.
Send to Compressor had a history of issues in legacy FCP.
