Intel Indeo 3 AVI file need to be able to convert to a format that will play
Geoff Edwards
on Aug 2, 2014 at 7:54:14 pm
Hi I have several short AVI videos recorded as Indeo 3 which I understand has been discontinued. I need advice as to how to convert these files to MP4 (I think that is the appropriate format)
Thanks Geoff
Craig Seeman
Re: Intel Indeo 3 AVI file need to be able to convert to a format that will play
on Aug 4, 2014 at 3:39:54 pm
You could try converting it in VLC although there might be a better way.
There's always the "cheat." If you can play the file you can capture it with a good screen grabbing program and convert it that way.
Geoff Edwards
on Nov 1, 2014 at 12:49:50 pm
Thanks Craig VLC works :)
