So.. What a good place to start as far as bitrate?
Blake Porter
on Jul 15, 2014 at 11:28:04 pm
Where's a good starting point for Bitrate selection?
I'm using Adobe Media Encoder CS5
This is for On Demand type web video in 720.
Thanks!!!
Craig Seeman
Re: So.. What a good place to start as far as bitrate?
on Jul 16, 2014 at 1:24:21 am
Are you going to upload to YouTube or Vimeo for their compression or are you doing the final compression to host it?
Vimeo recommendations
https://vimeo.com/help/compression
YouTube Recommendations
https://support.google.com/youtube/answer/1722171?hl=en
Bit rate usually depends on content. Talking heads lower, fast action sports or motion graphics higher.
Blake Porter
on Jul 16, 2014 at 2:12:40 am
Great question. We host own own. We offer 2 options: a High (720) and Low (640). Outdoor action, with LOTS of detail. Just wondered what your starting point might be for the 720?
My screen grab above shows my last test...
Craig Seeman
on Jul 16, 2014 at 5:55:39 am
For 1280x720 a range of 1500-5000kbps depending on content.
You could start at the low end and do a test encode over a complex section of about two minutes and see how it looks.
Outdoor with tree branches or leaves blowing or water rippling tends to be challenging. Also gradients found in some sky shots can also be a challenge.
On the other hand a reporter doing a stand up against a clear sky would be less challenging.
Blake Porter
on Jul 16, 2014 at 6:29:43 am
Thanks. I did a test at 1.81 Mbps and saw some deterioration (after a 2.25 Mbps test).
that's 1800kbps, and it looked OK. Not great but OK. Hmm... Our footage tends to be very challenging. Dang thanks for your feedback Craig Seeman. I'm open to any other feedback!
Rich Rubasch
on Jul 16, 2014 at 8:44:32 pm
I'll go back to my original suggestion and try 1400kbps at 960 x 540 and see how that looks, from a size/quality trade off.
Rich Rubasch
Tilt Media Inc.
Video Production, Post, Studio Sound Stage
Founder/President/Editor/Designer/Animator
http://www.tiltmedia.com
Blake Porter
on Jul 18, 2014 at 2:11:11 am
Wow. I'm kinda blown away by some of my latest test results!
