Best compression workflow FCP6 project for Bluray burning
Anne Davis
on Jun 1, 2014 at 11:08:39 pm
My Bluray burner came with Roxio Toast Platinum 11 and I'd like to try it for burning a Bluray disc
os a short project (under 10 minutes).
My version of Compressor is 3.0.5 so there is no "Share with Bluray" compressor preset option.
I could use one of these Compressor presets:
DVCProHD 720p24 (footage and editing codec used)
HD DVD H.264 60 minutes
HD uncompressed 8 0r 6 bit
Should I use Compressor first, try exporting a Quiktime .MOV version of the timeline and dragging
that file directly into Toast, or is there a better way I'm not considering?
Rob Gutermuth
Re: Best compression workflow FCP6 project for Bluray burning
on Jun 6, 2014 at 12:07:22 pm
upgrade to FCS3 (FCP7) and use compressor for the encode, and Toast for authoring... that would be the ideal thing... but...
there is a way to do it with your version of Compressor, by defining the MPEG 2 stream....
One note; everyone says that creating MP4 files for blu-ray is a bad idea... and mpeg2 is much better... I never tried mp4's even at H.264, so I can't comment, but stick with having compressor make you mpeg2's
I think ken stone had something on this with earlier versions of FCS/Compressor... I would not use Toast to do the encode, since you own compressor.
Rob Gutermuth
Media Creations
