Compressor Settings for MPEG-4
Joe Pegg
on May 5, 2014 at 11:55:27 am
Hi everyone :)
I'm using Compressor V3.2.3 and the client has asked me to provide the following:
MPEG-4
Container format: .mp4 or .mov (QuickTime H.264)
Video:
Bit rate / Quality: 30Mbps CBR minimum / Constant
Codec: H.264 / QuickTime
Frame size: 1920x1080
Frames per second: 25 (progressive scan)
Audio:
Codec: AAC
Channels: Stereo
Bit rate: 320 kbps
Sample rate: 48 KHz
Sample depth: 16 bit
Using Compressor I can't figure out how to set it up to provide everything I've been asked for.
Using MPEG-4 as my file format I'm restricted to 2Mbps.
Using QuickTime with MPEG-4 Codec i can set the data rate to 30Mbps, but not at a constant bit rate.
Is anyone able to help? I'd really appreciate it. Please let me know if you need any more information.
Joe Pegg
Re: Compressor Settings for MPEG-4
on May 5, 2014 at 4:12:46 pm
Just to add, the timeline is ProRes 422 and I have existing QTs exported at source resolution.
Craig Seeman
on May 5, 2014 at 4:40:15 pm
In order to encode H.264 .mp4 you'd need Compressor 4.
Compressor 3 only does H.264 .mov (or m4v for iOS devices).
