Combining a Premiere Pro and Final Cut Pro Project
Travis Roesler
on Feb 22, 2014 at 6:00:16 pm
Hey guys...
I edited some stuff a while ago and I've decided to replace some of the footage in the clips.... unfortunately I edited this in premiere pro.
I'm trying to figure out a workflow that will allow me to combine the work from these very different codecs.
I'm editing the Premiere Pro stuff as it's native AVCHD codec, HD 1080p using a Sony FS100.. the Final Cut stuff obvioulsy is in ProRes.
I have failed every time I've tried to turn my 1080p footage into prores using Adobe Media Encoder. In fact, I can't even find a setting that allows me to export in 1080p... only 1080i into prores. This comes out looking crappy.
I suppose the best alternative would be to convert the prores stuff into a good codec to combine with premiere's stuff.
Do you guys have any suggestions?
FCP7
PP 6.0.5
ame whatever the most recent version is (from cs6)
---Trav
Craig Seeman
Re: Combining a Premiere Pro and Final Cut Pro Project
on Feb 24, 2014 at 11:23:31 pm
[Travis Roesler] "I suppose the best alternative would be to convert the prores stuff into a good codec to combine with premiere's stuff. "
Current NLEs PremierePro CC and FCPX can both handle multiple codecs in a timeline. If you have AVCHD sources I'd convert those to ProRes rather than throwing away information by compression ProRes files.
