Compressor Not Adding Color Profile Metadata
Kieran Hanrahan
on Feb 4, 2014 at 6:28:54 pm
Hello,
Thanks in advance for any replies.
When using Compressor 3.5.3 to make a Prores422HQ from an RGB Uncompressed clip, the result clip is in Rec709 colorspace but it does not have the color profile 1-1-1 metadata added to it.
If my source file is YUV then the output file will have the color profile metadata applied to it. I can confirm this by viewing the info in the Finder.
This seems inconsistent to me. Am I missing a setting to force it to added the profile metadata? I have tried preserve source, Rec709, and Default for Encoder in Output Color Space menu. Right now, I use Automator to add the color profiles.
Thanks again
