Conversion problem detail are mention any kind of solution
Azhar Zafar Baloch
on Dec 21, 2013 at 6:17:49 am
Hello sir
MPEG stream conversion problem in camera mark conversion
problem conversion into any kind of codec
example proress xd cam extra also check
issue is contrast to much high converted footage but i check the original footage is OK
brightness shoot is proper converted clips getting problem
os upgraged istalled to backward also install all types of trick try to handle codec's install
Craig Seeman
Re: Conversion problem detail are mention any kind of solution
on Dec 23, 2013 at 9:01:19 pm
Converting can cause changes in levels. Some will use processing filters to compensate.
Azhar Zafar Baloch
on Jan 19, 2015 at 6:27:00 am
Sir Sorry for delaying reply ...
Problem solve hard drive issue....
If hard drive getting weak or work load on System.
Then conversion not proper working From Mpeg Stream And Also i change my grafix card not decklink card ..but issue is hard drive
now working ok thansk
