Some flickering scenes in DVD (from HDV in FC7)
Joaquín Mateo Morales
on Nov 21, 2013 at 6:13:27 pm
Hello
I have a little problem, when trying to burn a dvd from a HDV secuence in FC7 the resoult is a dvd with some flickering scenes. That is a kind of luma flickering to be precise. Some times it is a part of the image, let say..., the left superior corner... Other times the entire frame. It occurs most of the time in the bright parts of the image.
My workflow is the following: 1- In secuence settings I select ProRes 422, 2- Export/ Quicktime conversor/ ProRes 442, 3- Load it in Compressor, 4- 90 presetings/90 best, 5- Burn it with DVDPro
Anyone who could give me a clue of the causes of these flickerings? Any recomendation/solution?
Thank you very much for your help!!!
jey
