How encode an mpeg-4 mov with DV codec?
John Fishback
on Nov 19, 2013 at 11:03:40 pm
I have Compressor 4.0.7 & Squeeze 9. Can I do this with either?
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Craig Seeman
Re: How encode an mpeg-4 mov with DV codec?
on Nov 19, 2013 at 11:12:27 pm
DV codec is source?
Both can do that but I assume you mean H.264 (mpeg4 part 10) .mov. You could probably do the ancient mpeg4 part 2 but I'm not sure why you'd want that.
John Fishback
on Nov 21, 2013 at 2:43:09 pm
Our Pro Tools system likes DV movies for sync to picture. We don't have external Avid hardware for picture. A few months back I did an adr session for the Ray Donovan show and they supplied an mpeg-4 which worked because it was made with the dv codec. I'd like to know how t hat was done. Thanks.
John
