Desperate need of compression advice using Compressor/Final Cut Pro X
Mark Vlasic
on Oct 19, 2013 at 9:06:04 pm
Looking to compress a 90 minute feature film into a file around 5GB. I had a post house pull it off at 4.71GB but I made changes and don't have time to get it back to the post house. Any help would be greatly appreciated.
Craig Seeman
Re: Desperate need of compression advice using Compressor/Final Cut Pro X
on Oct 19, 2013 at 10:10:36 pm
High school math.
A car goes 50mph for 2 hours so it traveled 100 miltes
speed times duration equals distance.
speed times duration equals size
kibps times duration equals files sise.
Solve for kbps.
Steve McGarrigle
on Oct 20, 2013 at 5:33:33 pm
If it's afile size issue - remember that Compressor gives you the estimated file size as a calculation in the inspector when you are making your settings. As for what those settings should be? That depends on the files end purpose.
