Custom Frame size with Mpeg 2 compression?
Keith Wells
on Sep 13, 2013 at 6:59:15 pm
Does anyone know how to convert a 10bit Uncompressed Mov with the Custom frame size of 1344 x 384 to an MPG2. Its to be broadcast on a large LED Screen in China at that resolution. They are insisting on that frame size and that it be an MPG2. I know that the MPG2 algorithm doesn't like custom sizes but How can you get a custom frame size?
Ivan Myles
Re: Custom Frame size with Mpeg 2 compression?
on Sep 13, 2013 at 8:36:09 pm
Adobe Media Encoder supports custom dimensions for MPEG-2. Be sure to set Level to High. That should work with 1344x384.
MPEG-2 Profiles & Levels Wiki
Keith Wells
on Sep 14, 2013 at 7:52:01 pm
Thank you so much. Using Adobe Media Encoder from CS 5 worked really well after installing the updates. I got what I needed in the first encoding. I was using compressor and ffmpeg among other, nothing was doing it except a website which offered essentially zero control. I appreciate your comment.
thanks
Ivan Myles
on Sep 15, 2013 at 4:26:41 am
Happy to help. Glad it worked for you.
