.mpeg with split channels of audio, full stereomix and M&E mix
bradley greenwell
on Jun 11, 2013 at 10:55:17 pm
This scenario is bringing me to the brink of career change.
I have 28 - 29.97HD PBS programs that need to be converted to this
File MPEG-2:
- File format : . mpg
- Bitrate: 15Mbps (Constant bit rate)
- Res:720x576 – 4:2:2
- GOP: 15
- Frame rate: 25fps
- Audio: Stereo – 48Khz – 16 bit – 192 or 224 or 384 kbps
- Ch 1-full mix , Ch2- M/E
The main problem is getting the split tracks of audio, and maintaining the .mpeg file
I can convert the video and audio separately and then match them up through quicktime pro, but then i lose the .mpeg and get .mov.
Im using Final Cut Pro as well.
Any help would be MUCH APPRECIATED!
Bradley J.
