import motion codes to after effects (pro res)
Dawud Ali
on May 29, 2013 at 11:59:46 am
Hi
For specific needs I need to export with apple pro res codec from after effects, so I went ahead and got my hands on apple's 'motion'.
Now how do i get after effects to import those lovely pro res codecs. I restarted assuming they would be available but that didn't work. Do i need to somehow manually import those codecs in to after effects??
Thanks in advance
Craig Seeman
Re: import motion codes to after effects (pro res)
on May 29, 2013 at 12:19:11 pm
Try this link.
http://support.apple.com/kb/dl1396
Dawud Ali
on May 29, 2013 at 1:55:16 pm
Update,
thanks for the link but have not found the relavent post so far.
Now that i have apple's 'motion' I'm able to export with 'pro res' codecs on softwares such as motion and mpeg streamClip (type of converter) which is cool BUT for some strange reason pro res codecs are still not available to me in after effects.
Dawud Ali
on May 29, 2013 at 6:32:02 pm
