making an M2TS for festival projection
Stephen Vilash
on May 3, 2013 at 10:58:48 am
we need to provide a festival venue with an .m2ts file for digital projection.
the workflow for making a Bluray is something we've done in the past.
we bring in the Pro Res files to Compressor, make an elementary stream .m2v + AC3 sound, bring that together to a .ts file in MPEG Streamclip and its ready for burning with Toast.
however, i am confused about the workflow for an .m2ts file with these requirements:
Used video codec should be 100% compatible with the H264 codec and specifications used for blu ray disc.
• H264 Format
• Main Profile, level 4.1
• Maximum Video bitrate of 40 Mbit/s
• Maximum AV bitrate (combined audio and visual bitrate) of 48 Mbits
• Can be VBR or CBR bitrate
Used audio codec should be 100% compatible with the Dolby codec or PCM codec and specifications used for blu ray disc.
• Linear PCM (LPCM) up to 8 channels (7.1), uncompressed audio
• Maximum bitrate of 27Mbit/s
• However: maximum AV bitrate (combined audio and visual bitrate) of 48 Mbits
I am assuming i should make a Transport Stream of the Pro Res video, but what settings are needed in Compressor to have h264? also, what's the best compressor setting for LPCM sound file?
Once i have these, should I use MPEG Stremclip again to bring them to one file?
i only see the possibility to get files with a .ts extension, not an .m2ts
any professional help would be much appreciated!
