Streamclip Not Playing Video Properly...
Mark Pybus
on Apr 13, 2013 at 10:16:07 am
Hello,
Whenever I load a file into Streamclip (1.9.2), the top 1/5th of the video is cut off. This happens regardless of what type of file I load into Streamclip. When I export from Streamclip, the exported file is fine, but I'm not able to properly view the file before the export.
This is problematic as the files are quite long and I only want to export certain clips.
Any thoughts?
Thanks.
Macbook Pro 2.4Ghz
16MB RAM
OS 10.8.2
Jeff Greenberg
Re: Streamclip Not Playing Video Properly...
on Apr 15, 2013 at 4:02:43 pm
Since everything is working fine, but it's not displaying okay, this leads me more to believe that something odd is going on with your user than anything else.
A quick & dirty solution would be to trash the prefs: it.alfanet.squared5.MPEGStreamclip.plist
If that doesn't work, see what happens if you create a new user and if the problem remains.
Best,
Jeff I. Greenberg
Author/Master Instructor/Speaker/Consulting
My contact info and more
New! Come see me speak @ NAB/Post Production World!
Mike Weber
on Nov 15, 2017 at 10:45:11 pm
I had this same problem. This solution worked for me:
1) Be sure you have the most recent BETA version (1.93b8)
2) Open Applications folder, select MPEG Streamclip's application file, do "Get Info" (command-I)
3) check "Open In Low Resolution"
4) MPEG Streamclip should now work correctly.
Craig Seeman
on Nov 15, 2017 at 11:12:19 pm
Alas MPEGStreamclip developed stopped years ago. Note the beta (from 2012) never became a release version.
VLC is still very much alive for Playback and HandBrake for encoding otherwise it's time to move on to other players.
