tv does'nt support .MOV, any alternative render options?
hoff man
on Apr 2, 2013 at 11:32:47 am
in his blog http://www.videocopilot.net/blog/2007/0 ... -settings/
andrew suggests to use the quicktime render option.
i need to publish a short teaser for an office event but the samsung TV that would be playing the clip file does not support quicktime (.mov) format.
the supported codecs are .mp4 , .mkv, .avi, .wmv9
from these list, im not sure which format displays the same good quality as Quicktime - animation render option.
this site shows the complete supported codecs of the TV
http://www.samsung.com/uk/consumer/lear ... b_faq.html
would greatly appreciate your replies
Craig Seeman
Re: tv does'nt support .MOV, any alternative render options?
on Apr 2, 2013 at 2:30:43 pm
The extensions are containers, not codecs.
H.264, for example, can be .mov, .mp4, .f4v just to name a few.
wmv 9 is a codec within wmv which can contain other wmv variants such as wmv 8, wmv 7, etc.
Unfortunately your links are bad. Please fix if you want to share.
Jeff Greenberg
on Apr 2, 2013 at 5:59:05 pm
[hoff man] " the supported codecs are .mp4 , .mkv, .avi, .wmv9"
As Craig pointed out - those are architectures (buckets_ not codecs.
Both of your links were truncated - I can't look up what the TV can do.
Likely it'll do h.264 MP4 files. What are you using as a compression tool? If you're using compressor 4, you can make this sort of file.
Handbrake can probably do this for you as well (for free) - use the Apple TV setting.
Hope that helps (until you get us the other information!)
Best,
Jeff I. Greenberg
Author/Master Instructor/Speaker/Consulting
My contact info and more
New! Come see me speak @ NAB/Post Production World!
