Workflow / format recommendation
Shawn Hughes
on Mar 27, 2013 at 11:01:31 pm
I know this has been discussed ad nauseum, but I've researched until I got a headache.
I am trying to build a digital out, but for now, what I have is what I am going to use.
I am running a BetaCam SX. Composite out, XLR > unbalanced audio
Capture card is a SinoVideo PCI 2309 Proteus (7134 WDM)
The card gives me the following options:
YUY2
UYVY
RGB 555 (16 bit)
RGB 24
RGB 32
YVU9
I420
Video Decoder
NTSC_M
NTSC_M_J
NTSC_433
Which will give me the best footage to work with? I don't know what the output will be, and the computer I'm using is ancient.
Shawn
Craig Seeman
Re: Workflow / format recommendation
on Mar 28, 2013 at 1:42:46 am
It may well depend on what NLE you're going to use.
Wasn't that a TV capture card?
You can buy a Blackmagic Intensity Pro card with analog breakout cables really cheap.
You can buy a Blackmagic Studio card with SDI in. They're not that expensive.
Jeff Greenberg
on Mar 28, 2013 at 2:00:34 pm
Shawn, on the scale of 1-10 where I know what I'm talking about, I'd rate this a 5. I've never seen this equipment before and google searching is getting me anywhere.
I'd pick: YUY2 as thats likely YUV colorspace with 2 samples for the Chroma (422). None of the rest of them would be a good match for betacam tapes.
I think the decoder is to decode analog television streams.
Best,
Jeff I. Greenberg
Author/Master Instructor/Speaker/Consulting
My contact info and more
New! Come see me speak @ NAB/Post Production World!
Shawn Hughes
on Mar 28, 2013 at 11:00:16 pm
Jeff - That (decoder) makes perfect sense now. Useless..lol
Thanks for the suggestion. I'll test that shortly.
And, yeah, it's a crap card. It is a P34, but it says "Easy Your Life" on the top. Nothing else... LOL
Craig - Thank you for the suggestions. I don't own a desktop, and what my intent is portable ingest for spot news so I can upload to Ustream. Plus, I want to hold off purchasing until I can see if I can get the digital component connector figured out.
Thanks again!
Shawn
Craig Seeman
on Mar 29, 2013 at 12:43:41 am
[Shawn Hughes] "my intent is portable ingest for spot news so I can upload to Ustream."
Ustream? You want to live stream news?
I'd recommend either a MacBookPro or an Asus laptop with Thunderbolt. Get a Blackmagic UltraStudio Mini Recorder (HDMI and HD-SDI) Or UlstraStudio Express (adds analog breakout). You'll be able to record and stream live. Just add streaming software.
